Component: Barometer (BMP180) (Environmental)
Revision as of 12:21, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Environmental
Barometer (BMP180) component
Barometric pressure sensor with a I2C bus interface. Pressure range 300 to 1100 hPa. Temperature range -40 to +85 °C.
Please click here to download the component source project: FC_Comp_Source_temp/Pressure_Sensor_BMP180.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Pressure_Sensor_BMP180.fcfx
Altitude
Fc9-comp-macro.png Altitude
Calculates the altitude based on difference between actual pressure and the pressure at the sea level P0=1013.25 hPa.
Forced_Read
Fc9-comp-macro.png Forced_Read
I2C_Read_Register
Fc9-comp-macro.png I2C_Read_Register
Reads a byte value from a register on the device
I2C_Write_Register
Fc9-comp-macro.png I2C_Write_Register
Writes a byte value to a register on the device
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png Initialise
Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected.
ReadPressureFloat
Fc9-comp-macro.png ReadPressureFloat
Reads the pressure as a floating point value in Bars. Calls the ReadPressureRaw function and then converts to a meaningful value.
ReadTemperatureFloat
Fc9-comp-macro.png ReadTemperatureFloat
Reset
Fc9-comp-macro.png Reset
Resets the device
Fc9-conn-icon.png I2C Properties
Fc9-type-16-icon.png Slave Address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Sensor Properties
Fc9-type-16-icon.png Compensation
Compensation formulas in double precision floating point or 32 bit fixed point
Fc9-type-16-icon.png Humidity Oversampling
Fc9-type-16-icon.png Pressure Oversampling
Fc9-type-16-icon.png Temperature Oversampling
Fc9-type-16-icon.png Mode
Fc9-type-16-icon.png Standby Normal Mode (ms)
Fc9-type-16-icon.png Filter Coefficient
Fc9-conn-icon.png Simulation
