Component: RFID (EB052, RWD-MICODE) (Wireless)
Revision as of 12:21, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Wireless
RFID (EB052, RWD-MICODE) component
Low level routines for controlling a RF Solutions RFID interface Allows communications between Mifare, ICode and HiTag type RFID tags. Also available in the form of the EB052 RFID E-block.
Please click here to download the component source project: FC_Comp_Source_temp/RFID.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/RFID.fcfx
Reading the status
The status of the RFID module is read using the "GetRFIDStatus" macro which returns a byte which is then displayed using the PORTB pins. FC6 Icon.png RFID Status Status byte breakdown for Mifare.
Status byte breakdown for ICode.
Status byte breakdown for HiTag.
Status byte breakdown for EM Marin.
Reading and Writing Data
Example which talks to a ICode type card and allows the data to be read and written via a keypad. FC6 Icon.png RFID Read/Write
Macro compatibility
Not all the macros can be used with all card types, here is a list of RFID transponder types and the macros that are compatible.
DecrementRFIDValue
Fc9-comp-macro.png DecrementRFIDValue
Perfoms a 32-bit decrement on the number held in location page or block.
Fc9-u8-icon.png - BYTE Src
Page / Block
Fc9-u8-icon.png - BYTE Dst
Page / Block
Fc9-u8-icon.png - BYTE Key_Type
Needed for MIFARE Commands
FormatRFIDValue
Fc9-comp-macro.png FormatRFIDValue
Initialises the internal buffer of the Microcontroller so that it is ready to perform a Increment, Decrement or Transfer command.
GetRFIDStatus
Fc9-comp-macro.png GetRFIDStatus
Collect the status of the RFID device (see help for the explaination of the status byte).
GetRFIDTypeID
Fc9-comp-macro.png GetRFIDTypeID
Collects the 3 bytes required to determine which kind of MIFARE device is present. Stores the result into the local buffer 0 - 2 and returns the response of the module.
GetRFIDUID
Fc9-comp-macro.png GetRFIDUID
Collects the UID from a RFID device. Stores the result into the UID buffer and returns the response of the module.
IncrementRFIDValue
Fc9-comp-macro.png IncrementRFIDValue
Perfoms a 32-bit increment on the number held in location page or block.
Page / Block
Page / Block
Fc9-comp-macro.png Initialise
Configures the RFID device by presetting the Osc type and Mode via the Flowcode component properties.
ReadRFIDBlock
Fc9-comp-macro.png ReadRFIDBlock
Reads a block of information from the RFID device.
ReadRFIDBuffer
Fc9-comp-macro.png ReadRFIDBuffer
Reads a byte of data from the incoming buffer.
The address of the buffer 0 - 15
ReadRFIDUID
Fc9-comp-macro.png ReadRFIDUID
Reads a byte of data from the UID buffer.
The address of the buffer 0 - 7
StoreRFIDKey
Fc9-comp-macro.png StoreRFIDKey
Stores a 6 byte key for use with MIFARE type devices that require authorisation.
Key Location 0 - 31
Fc9-u8-icon.png - BYTE D0
Least significant byte of key
Fc9-u8-icon.png - BYTE D1
Fc9-u8-icon.png - BYTE D2
Fc9-u8-icon.png - BYTE D3
Fc9-u8-icon.png - BYTE D4
Fc9-u8-icon.png - BYTE D5
Most significant byte of key
TransferRFIDValue
Fc9-comp-macro.png TransferRFIDValue
Perfoms a 32-bit block data transfer on the number held in location page or block.
Page / Block
Page / Block
WriteRFIDBlock
Fc9-comp-macro.png WriteRFIDBlock
Writes a block of information to the RFID device.
Remote RFID Block Address.
WriteRFIDBuffer
Fc9-comp-macro.png WriteRFIDBuffer
Writes a byte of data to the outgoing buffer.
Fc9-u8-icon.png - BYTE Data
The data to be stored in the buffer location 0 - 255.
WriteRFIDModule
Fc9-comp-macro.png WriteRFIDModule
Stores a byte of data to the internal EEPROM of the RFID module at the address specified.
Fc9-type-16-icon.png Card_Type
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-5-icon.png CTS
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
