Component: API (RPI) (API Slave Devices)
| Version | 2.0 |
- 1 API (RPI) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ADCSample10
- 5.2 ADCSample8
- 5.3 I2CInitialise
- 5.4 I2CReceive
- 5.5 I2CRestart
- 5.6 I2CSend
- 5.7 I2CStart
- 5.8 I2CStop
- 5.9 I2CTransInit
- 5.10 I2CTransReceive
- 5.11 I2CTransSend
- 5.12 IOGetInputPin
- 5.13 IOSetOutputPin
- 5.14 Initialise
- 5.15 PWMDisable
- 5.16 PWMEnable
- 5.17 PWMSetDuty
- 5.18 PWMSetPrescaler
- 5.19 SPIInitialise
- 5.20 SPIPrescaler
- 5.21 SPITransfer
- 5.22 SPITransferTrans
- 5.23 UARTBaud
- 5.24 UARTCheckRX
- 5.25 UARTInitialise
- 5.26 UARTReceive
- 5.27 UARTSend
- 6 Property reference
API (RPI) component
Connects to a Raspberry Pi running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_temp/RPI_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/RPI_API_Comp.fcfx
The App Developer (RaspberryPi) component allows an Raspberry Pi to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Raspberry Pi hardware the board must first be pre-programmed with dedicated firmware.
The firmware file and Flowcode source project can be downloaded from here.
The IP Address to the Raspberry Pi hardware is selected via the SCADA_RPI component IP Address property.
When building the component into a App Developer project remember to expose the IP Address property to allow the end user to select the correct address for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
| App Developer Slave Digital Pin | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 |
| Device Port Pin | G2 | G3 | G4 | G5 | G6 | G7 | G8 | G9 | G10 | G11 | G12 | G13 | G14 | G15 | G16 | G17 | G18 | G19 | G20 | G21 | G22 | G23 | G24 | G25 | G26 | G27 |
| App Developer Slave Peripheral Pin | I2C SDA | I2C SCL | SPI MOSI | SPI MISO | SPI SCK | UART RX | UART TX | PWM 0 | PWM 1 |
| Device Port Pin | G2 | G3 | G10 | G9 | G11 | G15 | G14 | G12 | G13 |
ADCSample10
| ADCSample10 | |
| Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
| ADCChannel | |
| Range: 0-12 | |
ADCSample8
| ADCSample8 | |
| Reads the voltage present on an Alanog pin as an 8-bit value range 0-255 | |
| ADCChannel | |
| Range: 0-12 | |
I2CInitialise
| I2CInitialise | |
| Initialsie the I2C module ready for communications | |
| Channel | |
| Baud | |
I2CReceive
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| Last | |
I2CRestart
| I2CRestart | |
| Put the I2C Module into Restart mode | |
| Channel | |
I2CSend
| I2CSend | |
| Channel | |
| DataOut | |
I2CStart
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
I2CStop
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
I2CTransInit
I2CTransReceive
I2CTransSend
IOGetInputPin
| IOGetInputPin | |
| Pin | |
| Range: 0-29 | |
IOSetOutputPin
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| State | |
| Range: 0-1 | |
PWMDisable
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-1 | |
PWMEnable
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-1 | |
PWMSetDuty
| PWMSetDuty | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-5 | |
| Duty | |
PWMSetPrescaler
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Prescaler | |
| Period | |
SPIInitialise
| SPIInitialise | |
| Channel | |
SPIPrescaler
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
SPITransfer
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
SPITransferTrans
UARTBaud
UARTCheckRX
| UARTCheckRX | |
| Channel | |
UARTInitialise
| UARTInitialise | |
| Channel | |
UARTReceive
| UARTReceive | |
| Channel | |
UARTSend
| UARTSend | |
| Channel | |
| Data | |
