Component: Serial EEPROM (93C46) (EEPROM)
Revision as of 12:21, 3 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category EEPROM
Serial EEPROM (93C46) component
A simple example showing the bare bones used to create a component based on SPI communications. ORG pin must be connected to GND
Please click here to download the component source project: FC_Comp_Source_temp/Serial_EEPROM_(93C46).fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Serial_EEPROM_(93C46).fcfx
Erase
Fc9-comp-macro.png Erase
EraseAll
Fc9-comp-macro.png EraseAll
Read
Fc9-comp-macro.png Read
8bit mode address = 0 to 128 Data = 0 to 255 16bit mode address = 0 to 64 Data = 0 to 65535
Fc9-u8-icon.png - BYTE address
SendBits
Fc9-comp-macro.png SendBits
A simple example showing a generic way to write a register using I2C.
Fc9-u16-icon.png - UINT value
Fc9-u8-icon.png - BYTE length
Write
Fc9-comp-macro.png Write
Fc9-u16-icon.png - UINT Value
Fc9-type-16-icon.png Mode
Fc9-type-5-icon.png CS
EEPROM pin 1
Fc9-type-5-icon.png SK
EEPROM pin 2
Fc9-type-5-icon.png DI
EEPROM pin 3
Fc9-type-5-icon.png DO
EEPROM pin 4
Fc9-conn-icon.png Operations
Fc9-conn-icon.png Control Codes
