Component: Joystick (Sparkfun Quiic) (Analog Input)
Revision as of 12:21, 3 February 2023 by Wiki bot (talk | contribs)
Category Analog Input
Joystick (Sparkfun Quiic) component
An XY sprung joystick with click switch allowing for easy user input control. Connected using I2C bus.
Please click here to download the component source project: FC_Comp_Source_temp/Sparkfun_Quiic_Joystick.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Sparkfun_Quiic_Joystick.fcfx
Traffic Light Scenario
ChangeI2CAddress
ChangeI2CAddress
Allows the I2C Device address to be changed which in turn allows more then one RFID reader to sit on the same physical I2C bus. Returns 1 if succesful.
- BYTE NewAddress
Range: 8 to 119 or 0x08 - 0x77
- BOOL Return
CheckButton
CheckButton
Checks to see if the button has been pressed since the last read of CheckButton or ReadButton.
- BOOL Return
Initialises the I2C bus ready for communications with the module.
ReadAxis
ReadAxis
Reads a single axis of the joystick and returns as a signed integer value.
- BYTE Axis
Range 0-1 Where 0=X, 1=Y
- BOOL Type
0 = Signed (-512 to 511), 1 = Unsigned (0 to 1023)
- INT Return
ReadButton
ReadButton
Checks to see if the button is currently pressed
- BOOL Return
Return To Center
Decides if the joystick automatically returns to the center position when released. Yes: The joystick will return to the center when released. No: The joystick will remain in the current position when released.
Device Address
External device address used to communicate with the module. Default 32 or 0x20
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
Simulate Comms
Controls if we are using the panel simulation or simulating the I2C calls for use with an I2C injector.
API
