Component: Switch Extension ()
Revision as of 12:22, 3 February 2023 by Wiki bot (talk | contribs)
Author
Category
Switch Extension component
An extension to the default switch Overlays the switch with a mesh
Please click here to download the component source project: FC_Comp_Source_temp/Switch_ext.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Switch_ext.fcfx
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
