Component: Thermistor (Environmental)
Revision as of 12:22, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Environmental
Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. Default calibration is for the EBM003 module.
Please click here to download the component source project: FC_Comp_Source_temp/Thermistor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Thermistor.fcfx
CalculateTemperature
Fc9-comp-macro.png CalculateTemperature
Converts the input ADC value and returns the Temperature in tenths of degree C
Fc9-u16-icon.png - UINT ADCValue
ADC Reading to be converted
Fc9-s16-icon.png - INT Return
GetADCValue
Fc9-comp-macro.png GetADCValue
Returns the Raw ADC value from the Analogue Channel
GetIntegerTemperature
Fc9-comp-macro.png GetIntegerTemperature
Reads the ADC input and returns the calculated Temperature as Integer degrees C
GetRealTemperature
Fc9-comp-macro.png GetRealTemperature
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
SetChannel
Fc9-comp-macro.png SetChannel
Set the ADC Channel
Fc9-s16-icon.png - INT ChannelID
SetMinMax
Fc9-comp-macro.png SetMinMax
Set the minimum and maximum temperature values that can be shown and set on the thermometer readout.
Fc9-f32-icon.png - FLOAT Min
Minimum Value
Fc9-f32-icon.png - FLOAT Max
Maximum Value
SetTemperature
Fc9-comp-macro.png SetTemperature
Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
Fc9-f32-icon.png - FLOAT Temperature
Zero to one value - representing min-max of the sensor.
Fc9-conn-icon.png ADC Properties
Fc9-type-6-icon.png ADC Channel
The ADC channel to which the thermistor circuit is connected. It is assumed that the thermistor is connected between the ADC pin and 0V, with a fixed resistor connected between the ADC pin and +V.
Fc9-type-21-icon.png ADC Bit Resolution
Fc9-conn-icon.png Thermistor Properties
Fc9-type-16-icon.png Wiring
Specifies the arrangement of the Thermistor and Fixed Resistor. Pull Down - Thermistor connected between ADC pin and GND, fixed resistor between ADC pin and VCC. Pull Up - Thermistor connected between ADC pin and VCC, fixed resistor between ADC pin and GND.
Fc9-type-21-icon.png Resistor Value
Value in Ohms of the pullup series resistor. i.e. The resistor is connected between the ADC pin and the positive supply rail.
Fc9-type-21-icon.png -25C Thermistor Value
Value in Ohms of the Thermistor at -25 deg C
Fc9-type-21-icon.png 0C Thermistor Value
Value in Ohms of the Thermistor at 0 deg C
Fc9-type-21-icon.png 25C Thermistor Value
Value in Ohms of the Thermistor at 25 deg C
Fc9-type-21-icon.png 50C Thermistor Value
Value in Ohms of the Thermistor at 50 deg C
Fc9-type-21-icon.png 75C Thermistor Value
Value in Ohms of the Thermistor at 75 deg C
Fc9-type-21-icon.png 100C Thermistor Value
Value in Ohms of the Thermistor at 100 deg C
Fc9-type-21-icon.png 125C Thermistor Value
Value in Ohms of the Thermistor at 125 deg C
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
A text label to help you identify the component on the panel.
Fc9-type-15-icon.png Min. Temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Fc9-type-15-icon.png Max. Temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Fc9-type-21-icon.png Scale divisions
Number of numbered divisions shown on the thermometer scale.
