Component: Switch (Slide, PCB) ()
Revision as of 12:23, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category
Switch (Slide, PCB) component
Subminiature slide switch with black tang, PCB mount.
Please click here to download the component source project: FC_Comp_Source_temp/sw_slide_sub_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/sw_slide_sub_pcb.fcfx
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
Connection
The chip pin to which this switch is connected.
Polarity
Sets whether the pin should go high or low when the switch is activated.
Debounce (ms)
Time in milliseconds allowed for the chip pin to stabilise following a change of state. NB) Debouncing is only used when reading the switch state using the component macros. Chip pin is NOT debounced.
Operation
Operation of the switch. Latching - the switch toggles state with each mouse click, and stays in position when released. Momentary - the switch turns on when the mouse is clicked, and turns off when the mouse is released.
