Component: DMA (CAL) (Misc)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Category Misc
DMA (CAL) component
CAL - Code Abstraction Layer A low level implementation giving direct access to DMA routines.
Please click here to download the component source project: FC_Comp_Source_DMA.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DMA.fcfx
Disable
Fc9-comp-macro.png Disable
Disables the DMA channel.
Enable
Fc9-comp-macro.png Enable
Initialise the DMA channel ready to process data to or from a peripheral. The user must enable the corresponding DMA interrupt after initialising the channel.
ReadBuffer16
Fc9-comp-macro.png ReadBuffer16
Fc9-u16-icon.png - UINT Data
ReadBuffer32
Fc9-comp-macro.png ReadBuffer32
Fc9-u32-icon.png - ULONG Data
ReadBuffer8
Fc9-comp-macro.png ReadBuffer8
Fc9-u8-icon.png - BYTE Data
WriteBuffer16
Fc9-comp-macro.png WriteBuffer16
WriteBuffer32
Fc9-comp-macro.png WriteBuffer32
WriteBuffer8
Fc9-comp-macro.png WriteBuffer8
Fc9-type-7-icon.png Enabled
Enables or Disables the DMA component from generating code.
Fc9-type-16-icon.png Channel
DMA Peripheral Channel Each utilised DMA enabled component should use a unique channel number
Fc9-type-7-icon.png Ping Pong
Controls the ping pong mode. True - Ping pong enabled, DMA memory double buffered to allow for seamless data sampling False - Ping pong disabled, DMA memory single buffered
Fc9-type-16-icon.png Mode
Fc9-type-16-icon.png DMA Type
Fc9-type-16-icon.png Peripheral
Fc9-type-21-icon.png Size
