Component: HBRIDGE (CAL) (Misc)
Revision as of 10:23, 24 February 2023 by Wiki bot (talk | contribs)
Version 2.1
Category Misc
HBRIDGE component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the H-Bridge peripheral. Currently only supports compatible 8-bit PIC devices.
Please click here to download the component source project: FC_Comp_Source_HBRIDGE.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_HBRIDGE.fcfx
Half Bridge Application
A Half Bridge type output has two output signals A and B.
Full Bridge Application
Full Bridge type output has four output signals A, B, C and D.
A simple proof of concept example to drive a full bridge output with varying speed and direction.
FC6 Icon.png PIC16F1937 H-Bridge Example
FC6 Icon.png PIC16F18877 H-Bridge Example
Disable
Fc9-comp-macro.png Disable
Disable this PWM Channel
Enable
Fc9-comp-macro.png Enable
Enable this PWM Channel
GetList
Fc9-comp-macro.png GetList
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property
Fc9-string-icon.png - STRING Name
GetValue
Fc9-comp-macro.png GetValue
Returns Named property Value
SetDirection
Fc9-comp-macro.png SetDirection
Set the motor direction.
Fc9-u8-icon.png - BYTE direction
0 = Forwards, 1 = Reverse
SetSpeed
Fc9-comp-macro.png SetSpeed
Sets the motor speed by varying the PWM duty.
Fc9-u16-icon.png - UINT duty
Duty value 0 - 1023
SetValue
Fc9-comp-macro.png SetValue
Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD)
Fc9-string-icon.png - STRING Value
Fc9-type-7-icon.png Enable
Fc9-conn-icon.png Settings
Fc9-type-16-icon.png Channel
PWM Channel selector
Fc9-type-16-icon.png Mode
Selects between full bridge and half bridge output modes. Some H-Bridge channels may only have one mode in which case the property selector will only show the available mode.
Fc9-type-16-icon.png Polarity
Selects the active output voltage. Active high - Pins will be low when inactive and high when active. Active Low- Pins will be high when inactive and low when active.
Fc9-type-16-icon.png Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Fc9-type-16-icon.png Prescaler Divide
Prescaler Divider value
Fc9-type-14-icon.png Period Register
PWM Period Register value
Fc9-conn-icon.png Dead Band
Fc9-type-21-icon.png Rising Bits
Number of bits assigned to the rising edge dead band counter. Auto populated based on selected target chip.
Fc9-type-21-icon.png Falling Bits
Number of bits assigned to the falling edge dead band counter. Auto populated based on selected target chip.
Fc9-type-21-icon.png Rising Count
Number of cycles to wait after a falling edge and before a rising edge.
Fc9-type-21-icon.png Falling Count
Number of cycles to wait after a rising edge and before a falling edge.
Fc9-type-5-icon.png A Pin
Output Pin A
Fc9-type-5-icon.png B Pin
Output Pin B
Fc9-type-5-icon.png C Pin
Output Pin C
Fc9-type-5-icon.png D Pin
Output Pin D
Fc9-type-16-icon.png A Remap Pin
Remap Pin A - Specifies the pin used for the A output. Only available on devices supporting remappable hardware pins.
Fc9-type-16-icon.png B Remap Pin
Remap Pin B - Specifies the pin used for the B output. Only available on devices supporting remappable hardware pins.
Fc9-type-16-icon.png C Remap Pin
Remap Pin C - Specifies the pin used for the C output. Only available on devices supporting remappable hardware pins.
Fc9-type-16-icon.png D Remap Pin
Remap Pin D - Specifies the pin used for the D output. Only available on devices supporting remappable hardware pins.
Fc9-conn-icon.png Calculations
Fc9-type-14-icon.png Clock Speed
Target Microcontroller Clock Speed.
Fc9-type-15-icon.png Period (uS)
Calculated length of PWM period in micro seconds.
Fc9-type-15-icon.png Frequency (KHz)
Calculated PWM output frequency in KHz.
Fc9-type-15-icon.png Frequency (Hz)
Calculated PWM output frequency in Hz.
