Component: BBC Weather Observation (Comms: IoT/Cloud)
| Author | MatrixTSL |
| Category | Comms: IoT/Cloud |
BBC Weather Observation component
Easily allows you to collect observed weather metrics for your area using the BBC Weather data service. Supports temperature and humidty for your selected area. Also available are Wind Direction, Wind Speed and Air Pressure but please note these are not always available depending on your selected area.
Please click here to download the component source project: FC_Comp_Source_BBCWeatherObservation.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_BBCWeatherObservation.fcfx
Here is a basic example to read the observation data and report the information on a graphical display.
The location can be set by adjusting the BBC Weather location property, see the component property tooltips for more information on how to do this.
On an embedded device you would need a TCP/IP component to allow the communications to the BBC server. This then links to the Network Comms component.
GetHumidity
| GetHumidity | |
| Reads the reported humidity in Relative Humdity. | |
GetLocationName
| GetLocationName | |
| Reads the reported location name as a string. | |
GetPressure
| GetPressure | |
| Reads the reported air pressure in milli bar (mb). Please note this data may not be available for your selected location. | |
GetTemperature
| GetTemperature | |
| Reads the reported temperature in the selected scale. | |
| Scale | |
| 0 = Celcius, 1 = Farenheit | |
GetWindDirection
| GetWindDirection | |
| Reads the reported wind direction as a string. Please note this data may not be available for your selected location. | |
GetWindSpeed
| GetWindSpeed | |
| Reads the reported wind speed in MPH. Please note this data may not be available for your selected location. | |
| Sets up the component ready to collect weather data. | |
RequestData
SetLocationCode
