Component: GLCD Base (Graphical Library)
Revision as of 08:05, 27 March 2023 by Wiki bot (talk | contribs)
Version 3.0
Category Graphical Library
GLCD Base component
Base graphical LCD with simulation only interface to allow graphics to be drawn in simulation. Suitable for inheriting to simplify the creation of further graphical LCD components.
Please click here to download the component source project: FC_Comp_Source_GLCD_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_base.fcfx
Font sizes
Standard Fonts
0 = Normal
1 = 2 x Width
2 = 2 x Width and 2 x Height
3 = 2 x Height
Extended Fonts
4 = 2 x Width and 3 x Height
5 = 2 x Width and 4 x Height
6 = 2 x Width and 5 x Height
7 = 2 x Width and 6 x Height
8 = 3 x width
9 = 3 x Width and 2 x Height
10 = 3 x Width and 3 x Height
11 = 3 x Width and 4 x Height
12 = 3 x Width and 5 x Height
13 = 3 x Width and 6 x Height
14 = 4 x width
15 = 4 x Width and 2 x Height
16 = 4 x Width and 3 x Height
17 = 4 x Width and 4 x Height
18 = 4 x Width and 5 x Height
19 = 4 x Width and 6 x Height
20 = 5 x width
21 = 5 x Width and 2 x Height
22 = 5 x Width and 3 x Height
23 = 5 x Width and 4 x Height
24 = 5 x Width and 5 x Height
25 = 5 x Width and 6 x Height
26 = 6 x width
27 = 6 x Width and 2 x Height
28 = 6 x Width and 3 x Height
29 = 6 x Width and 4 x Height
30 = 6 x Width and 5 x Height
31 = 6 x Width and 6 x Height
EBM001 Basic Example
EBM001 gLCD Example File
EBM001 Example
EBM001 Maze Builder
Maze Builder gLCD
3D Manipulations
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawEnd
DrawEnd
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
Draws a rectangle with the current foreground colour from pixel loaction X1, Y1 to pixel location X2, Y2.
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
DrawStart
DrawStart
Ev_Initialise
Ev_Initialise
Initialisation routine for the component once the component is linked to its parent
- ULONG Return
FastPlot
FastPlot
Sets a pixel with the current foreground colour at current pixel location.
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontByte
ReadFontByte
Gets a byte from the selected embedded ASCII font data.
- BYTE Font
- BYTE Character
ASCII character for example 'A' or 65
- BYTE ByteIndex
Font column Ranging 0-4
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
Window
Window
Specifies a specific window in the pixels to draw to.
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Colour
Specifies the initial foreground colour for shapes and text.
Background Colour
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Show Background Elements
Show or hide features like the title and background.
Component Label
Component Label Scale
Display Method
Embed Font Set
Specifies if the font set is included with the embedded downloadable code. Some display types have in an built font and text functions so the embedded font set can be disabled to reduce code overhead. For other display types the embedded font data should be enable to allow the print functions to work correctly.
Num Parents
Number of parent levels to jump up to get the auto title name. For most GLCDs it will be 1. For most Alpha LCDs it will be 2.
Show GLCD Icon
Show the GLCD connectivity icon, Set to Yes for GLCDs and No for other none standard things e.g. Alphanumeric LCDs.
TouchHandler
Physical Orientation
