Component: Level (DSP Outputs)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Outputs
Level component
Allows for detection and collection of peaks, troughs and averages.
Please click here to download the component source project: FC_Comp_Source_DSP_Level.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Level.fcfx
Here is a basic example of the Level component. The example collects the max, min and average readings from the buffer and displays them on the LCD display.
FC6 Icon.png Level
The values in the buffer are defined using the InputADC component.
Min: Minimum (smallest) value read from the buffer.
Max: Maximum (largest) value read from the buffer.
Average: Rolling average calculated from the values inside the buffer.
ReadAverage
Fc9-comp-macro.png ReadAverage
Returns the average from the last "Decay" number of index locations.
ReadAverageArray
Fc9-comp-macro.png ReadAverageArray
Returns the average from the last "Decay" number of buffers.
ReadPeak
Fc9-comp-macro.png ReadPeak
Returns the highest value from the last "Decay" number of index locations.
ReadPeakArray
Fc9-comp-macro.png ReadPeakArray
Returns the highest value from the last "Decay" number of buffers.
ReadTrough
Fc9-comp-macro.png ReadTrough
Returns the lowest value from the last "Decay" number of index locations.
ReadTroughArray
Fc9-comp-macro.png ReadTroughArray
Returns the lowest value from the last "Decay" number of buffers.
ResetRecords
Fc9-comp-macro.png ResetRecords
Allows the peak and trough to be reset back to default values.
Fc9-bool-icon.png - BOOL ResetPeak
Fc9-bool-icon.png - BOOL ResetTrough
Fc9-type-16-icon.png Connect To
Fc9-type-7-icon.png Decay on Peak/Trough
Yes - The Peak and Trough value will only be maintained for the decay number of buffers. No - The record Peak and Trough values will be maintained until reset.
Fc9-type-14-icon.png Decay
Configures how many buffers or values to allow a record to persist
