| Author
Matrix Ltd
| Version
1.2
| Category
DSP Inputs
A waveform generator component designed to plug into the DSP system component and allow several discreet waveforms to be generated. Functions available include: Sine, Cosine, Square, Pulse, Triangle, Sawtooth, Noise, Custom
Please click here to download the component source project: FC_Comp_Source_DSP_Wave_Gen.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Wave_Gen.fcfx
Basic Sine Wave Generator
FreqGen
The frequency is controlled by adjusting the potentiometer on the panel.
The frequency generator period is controlled using the Period Offset property and/or the SetOffset component macro. The Offset value is the LUT index multiplier so a offset of 3.0 will only read every 3 values of the waveform to provide 1/3 of the period and generate 3 x the frequency. As the waveform period is being reduced there is potential for the signal to start to become less defined and more stepped.
Multi Wave Signal Generator
Switch-able mode frequency generator example file generating different waveforms depending on the value on pins RB0 and RB1.
0 = Sine, 1 = Square, 2 = Triangle, 3 = SawTooth
FreqGenMulti
The frequency is controlled by adjusting the potentiometer on the panel, the waveform is controlled by adjusting the switches on the panel.
Generate
Generate
| Assigns a single value to the specified buffer from the selected waveform data. Each call will read the next value from the waveform and will wrap correctly at the end of the data period.
GenerateArray
GenerateArray
| Fills the output buffer with the selected waveform data. If the buffer is smaller or larger then the waveform data period then the data passed will follow on correctly for subsequent cycles.
GetOffset
GetOffset
- UINT
ModifyFrequency
ModifyFrequency
| Sets the frequency output rate by altering the period offset to a new value.
- FLOAT
OffsetRate
| 0.2=F/5 0.5=F/2 1.0=F 1.5=F*1.5 2.0=F*2
ModifyPhaseOffset
ModifyPhaseOffset
| Shifts the output phase by the specified absolute angle in degrees.
- FLOAT
PhaseOffset
| Phase offset in degrees
- BOOL
Absolute
| 0=Relative offset to current o/p 1=Absolute offset to initial o/p
SetOffset
SetOffset
- UINT
Offset
Buffer Size
| Number of individual elements the buffer can store, default 1.
Buffer Type
| Sets the buffer data type.
Waveform
Type
| Waveform type selection
Amplitude
| Waveform amplitude or volume
Offset
| Waveform DC offset
Calculate Data
| Yes = Allows Sine, Cosine, Noise data to be generated on the fly using a calculation, provides much better resolution at the cost of processing performance. No = Allows Sine, Cosine, Noise data to be generated ahead of run time, provides fixed resolution output but is fast and efficient to generate.
Samples
| Waveform sample count, the number of data points in the stored cyclic wave look up table.
Start Phase Angle
| Waveform phase, the angle in degrees or sample in the wave to start streaming from
Data
| The raw waveform data
Period Offset
| The initial amount that the index increments through the LUT data when reading the stored waveform. 0.2 = Frequency / 5 0.5 = Frequency / 2 1.0 = Original Frequency 1.5 = Frequency * 1.5 2.0 = Frequency * 2
Sample Period
| Degrees per default sample offset period
Frequency Calculation
Sample Rate (hz)
| Allows the sample rate to be entered to allow some basic calculations
Period (s)
| The length of time in seconds that the wave period will cover at the specified sample rate
Frequency (hz)
| The repeat frequency of the wave at the specified sample rate
