Component: Combo (BL0114) (E-blocks 2)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
Combo component
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
IO_GetPort
Fc9-comp-macro.png IO_GetPort
Reads the state of a single port
Fc9-u8-icon.png - BYTE Bank
0 = Top Bank of Switches, 1 = Bottom Bank of Switches
IO_GetSwitchState
Fc9-comp-macro.png IO_GetSwitchState
Reads the state of a single switch Returns: 0 = Switch not pressed, 1 = Switch pressed
Fc9-u8-icon.png - BYTE Switch
0 = SW0, 7 = SW7
IO_ReadAnalogAsByte
Fc9-comp-macro.png IO_ReadAnalogAsByte
Reads one of the analogue components as an byte value
0 = Light Sensor, 1 = Potentiometer
IO_ReadAnalogAsInt
Fc9-comp-macro.png IO_ReadAnalogAsInt
Reads one of the analogue components as an Integer value
Fc9-s16-icon.png - INT Return
IO_SetLEDState
Fc9-comp-macro.png IO_SetLEDState
Sets the state of a single LED
0 = Top Bank of LEDs, 1 = Bottom Bank of LEDs
Fc9-u8-icon.png - BYTE LED
0 = LED0, 7 = LED7
Fc9-u8-icon.png - BYTE State
0 = Off, 1 = On
IO_SetPort
Fc9-comp-macro.png IO_SetPort
Sets the state of a single port
Fc9-u8-icon.png - BYTE Value
LCD_Clear
Fc9-comp-macro.png LCD_Clear
LCD_ClearLine
Fc9-comp-macro.png LCD_ClearLine
Fc9-u8-icon.png - BYTE Line
The line to clear, zero being the first (top) line of the display
LCD_Command
Fc9-comp-macro.png LCD_Command
Fc9-u8-icon.png - BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
LCD_Cursor
Fc9-comp-macro.png LCD_Cursor
Fc9-u8-icon.png - BYTE x
Set the cursor position in the X plane, 0 is the left most cell
Fc9-u8-icon.png - BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
LCD_PrintAscii
Fc9-comp-macro.png LCD_PrintAscii
Fc9-u8-icon.png - BYTE character
Holds an ascii value.
LCD_PrintFloat
Fc9-comp-macro.png LCD_PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
LCD_PrintFormattedNumber
Fc9-comp-macro.png LCD_PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
LCD_PrintNumber
Fc9-comp-macro.png LCD_PrintNumber
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
LCD_PrintString
Fc9-comp-macro.png LCD_PrintString
Enter the text or variable to print to the LCD
LCD_RAMWrite
Fc9-comp-macro.png LCD_RAMWrite
Fc9-u8-icon.png - BYTE Index
Values 0 to 7
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
LCD_RawSend
Fc9-comp-macro.png LCD_RawSend
Sends data to the LCD display
Fc9-u8-icon.png - BYTE data
The data byte to send to the LCD
Fc9-bool-icon.png - BOOL type
A boolean to indicate command type: true to write data, false to write a command
LCD_RemapCharacter
Fc9-comp-macro.png LCD_RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
Fc9-u8-icon.png - BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
Fc9-u8-icon.png - BYTE SearchCharacter
Character to look for a replace
Fc9-u8-icon.png - BYTE ReplacementCharacter
New character value to use in place of the search character.
LCD_ScrollDisplay
Fc9-comp-macro.png LCD_ScrollDisplay
Fc9-u8-icon.png - BYTE Position
Holds the number of positions to shift the display
Fc9-u8-icon.png - BYTE Direction
0 = left, 1 = right
LCD_Start
Fc9-comp-macro.png LCD_Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Seg_ShowDigit
Fc9-comp-macro.png Seg_ShowDigit
Displays a digit on the 7-seg display
Fc9-u8-icon.png - BYTE Digit
Which of the digits to change (0 - 3)
The value to display (0 - 9)
Fc9-u8-icon.png - BYTE DecimalPoint
Decides if the decimal point is lit
Seg_ShowSegments
Fc9-comp-macro.png Seg_ShowSegments
Allows the individual segments of the display to be controlled.
Fc9-u8-icon.png - BYTE Segments
8-bit Binary value to set the segments, bit0 = segA, bit1 = segB...
Fc9-type-16-icon.png Connection Type
Fc9-conn-icon.png Bank 0 Connections
Fc9-type-19-icon.png Bank 0
Fc9-conn-icon.png Bank 1 Connections
Fc9-type-19-icon.png Bank 1
Fc9-conn-icon.png Analog Connections
Fc9-type-6-icon.png Light Sensor
Light Sensor ADC channel Connected to Bank 0 pin 0 which is usually analog pin AN0.
Fc9-type-6-icon.png Potentiometer
Potentiometer ADC channel Connected to Bank 0 pin 1 which is usually analog pin AN1.
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Analog Scope Traces
Controls if traces are automatically added to the data recorder window for the analogue signals on the combo board.
