API Panel.Position.RotateY
Revision as of 21:19, 21 May 2013 by (username removed)
<sidebar>API contents</sidebar> Rotates the object around the Y axis
Class hierarchy
Panel
Position
RotateY
HANDLE Handle
HANDLE PivotHandle
An optional position to treat as the origin to rotate around
FLOAT Degrees
Number of degrees to rotate by
There are several api calls that deal with rotation of an object and the effects can be quite complex. Here we are going to deal exlusively with the RotateY() api call. An object can rotate around it's own axis(x,y,z), or around the axis of another object's axis(x,y,x) if a different object is named as the pivothandle in the api call. When dealing with rotation in Flowcode it is important therefore to understand the following points
  1. Rotation of an object occurs from the centre of an object or group.
  2. The axis orientation of the object or group may well be different from the axis on the system panel(world axis)
  3. The axis orientation of another object if used as a pivothandle could be different from the object to rotate.
Rotating around an object's own axis
This technique is the simplest way of rotating an object or group when the type of rotation required is not relative to any other object or component. The image to the right shows a cube with it's axis positions identified. Note in this context the x,y,z axis is illustrated just to highlight the explanation of technique, it is not representative of the axis position in Flowcode v6.
Calling the simulation api Panel.Position.RotateY(MyCube,MyCube,1) will rotate the object in one-degree steps along it's X-axis as shown by the green rotation arc. To rotate the cube in a counter direction simply specify a negative number for the degrees parameter.
The screenshot from Flowcode v6 below shows a cubiod with it's internal axis shown (green is the Y-axis line), and also a green circle that cuts right through the cuboid's Y-axis (see example section below for links to the file) When the program runs the cuboid rotates along it's Y axis. Note also incidentally the cuboids axis is also the same as the world axis but this might not always be the case.SIMAPI Panel Position RotateY Pic2.png
  • Add to a calculation icon:
    ::Panel.Position.RotateY(handle, pivothandle, degrees)
Download File:SIMAPI Panel Position RotateY v1.fcf and open it in Flowcode v6.
