Component: HTTP Fetch ( Comms)
Revision as of 09:50, 4 December 2023 by BenR (talk | contribs) (Examples)
Author MatrixTSL
Version 0.1
Category Comms
HTTP Fetch component
Component designed to request resources from an external HTTP server.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Fetch.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Fetch.fcsx
HTTP
Example program showing how to retreive the HTML source of a HTTP URL.
Fetch HTTP Example
The HTML source is hosted at the following URL: http://www.flowcode.co.uk/example/fetchtest.txt
File:fetchtest.txt
HTTP JSON Encoded
Example program showing how to retreive the HTML source of a HTTP URL. Here the source is encoded JSON data which we can parse through.
Fetch HTTP JSON Example
The HTML source is hosted at the following URL: http://www.flowcode.co.uk/example/jsonfetchtest.txt
File:jsonfetchtest.txt
HTTP JSON Encoded Time and Date
Example program showing how to retreive the HTML source of a HTTP URL. Here the source is encoded JSON data which we can parse through. The data is created using a PHP script which allows for dynamic data such as the current time and date.
Fetch HTTP Time Date Example
The HTML source is hosted at the following URL: http://www.flowcode.co.uk/example/jsonfetchtimedate.php
Please note the file type for the file below has been changed from .php to .txt to be allowed onto the Wiki.
File:jsonfetchtimedate.txt
Fetch Parameters
Example program showing how to retreive the JSON data source of a HTTP URL. Here the source is encoded JSON data which we can parse through. The data is created using a PHP script which allows for dynamic data in this case based on the selection made using the radio buttons.
Fetch Parameter Example
The HTML source is hosted at the following URL: http://www.flowcode.co.uk/example/get_data.php
File:get_data.txt
Weather Example
Example program showcasing a number of components used together to collect data from a URL using fetch, before processing the data using the object helper and array helper components.
Web Weather Example
Fetch
Fetch
Start the process of fetching a resource from a web server
- STRING sParams
Parameters for the Fetch call
SetMacro
SetMacro
- STRING sMacro
SetURL
SetURL
Sets the URL for the Fetch call
- STRING sURL
URL
Call macro
