Component: File (ESP32 SDMode) (File)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 2.7 |
Category | File |
- 1 File (ESP32 SDMode) component
- 2 Detailed description
- 3 Examples
- 4 Macro reference
- 4.1 AppendByteArrayToFile
- 4.2 AppendByteToFile
- 4.3 AppendFloatArrayToFile
- 4.4 AppendINTArrayToFile
- 4.5 AppendLongArrayToFile
- 4.6 AppendStringToFile
- 4.7 CloseFile
- 4.8 CreateFile
- 4.9 DeleteFile
- 4.10 Initialise
- 4.11 MoveToNextFileSector
- 4.12 OpenFile
- 4.13 OpenFolder
- 4.14 ReadByteArrayFromFile
- 4.15 ReadByteFromFile
- 4.16 ReadByteFromIndex
- 4.17 ReadFileLength
- 4.18 ReadFileSize
- 4.19 ReadFloatArrayFromFile
- 4.20 ReadINTArrayFromFile
- 4.21 ReadLongArrayFromFile
- 4.22 ReadStringFromFile
- 4.23 SetFileIndex
- 4.24 Uninitialise
- 4.25 WriteByteToBuffer
- 4.26 WriteFileSector
- 5 Property reference
- 6 Component Source Code
File component allowing access to read and write files on an SD card using the ESP32 SD Mode IO allowing for high speed data transfer using 1-bit or 4-bit SD access.
Line Following
Line following example using the Formula AllCode, works with objects on the simulation panel and on the real hardware.
Simulation with the API component
An example showing how to use the API component to drive the robot in simulation.
AppendByteArrayToFile |
Data |
Length |
Return |
AppendByteToFile
AppendByteToFile |
Data |
Return |
AppendStringToFile
AppendStringToFile |
Data_String |
Return |
CloseFile
CloseFile |
Return |
CreateFile
CreateFile |
Filename |
Return |
DeleteFile
DeleteFile |
Filename |
Return |
Initialise |
Starts up the SD card interface and checks to see if a card is compatible. Returns: 0=OK, 255=No Card, 254=File System Fail | |
Return |
MoveToNextFileSector |
Not currently implemented on the RPI | |
ForceNextSector |
Return |
OpenFile
OpenFolder
OpenFolder |
Folder_Name |
Return |
ReadByteArrayFromFile |
Reads a binary byte array from the currently open file. Auto increments the position in the file. Returns the number of values read. | |
Data |
Length |
Return |
ReadByteFromFile
ReadByteFromIndex
ReadByteFromIndex |
Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer. | |
Address |
Return |
ReadFileLength
ReadFileLength |
Return |
ReadFileSize
ReadFileSize |
Reads the entire size of the current file in bytes. | |
Return |
ReadStringFromFile
SetFileIndex
SetFileIndex |
File_Index |
Range: 0 to 4 | |
Return |
Uninitialise
Uninitialise |
Terminates connection to the SD card, unmounts the SD card and disabled the SD peripheral. | |
Return |
WriteByteToBuffer
WriteByteToBuffer |
Address |
Data |
Return |
WriteFileSector
WriteFileSector |
Return |
Please click here to download the component source project: FC_Comp_Source_File_ESP32_SDMode.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_File_ESP32_SDMode.fcfx
