Component: Potentiometer (Analog Input)
| Category | Analog Input |
Potentiometer component
Please click here to download the component source project: FC_Comp_Source_Potentiometer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Potentiometer.fcfx
Filtering ADC Inputs
Analogue Inputs Window
The Analogue inputs window available from the View ribbon, allows you to see the values for all of the analogue inputs which are active in your program. They can also be manually altered by dragging the mouse along one of the sliders.
GetAverageByte
|   | GetAverageByte |
| Read the ADC as a byte | |
|  - BYTE | NumSamples |
|  - BYTE | DelayUs |
|  - BYTE | Return |
GetAverageInt
|   | GetAverageInt |
| Read the ADC at full bit depth | |
|  - BYTE | DelayUs |
|  - UINT | Return |
GetByte
|   | GetByte |
|  - BYTE | Return |
GetInt
|   | GetInt |
|  - UINT | Return |
GetString
|   | GetString |
| Reads the ADC as a direct voltage | |
|  - STRING | Return |
GetVoltage
|   | GetVoltage |
|  - FLOAT | Return |
