Component: TCP/IP (ENC28J60) (Comms: Networking)
| Version | 2.2 |
| Category | Comms: Networking |
- 1 TCP/IP (ENC28J60) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 CheckArpPacketIsMyreplyArp
- 5.2 CheckForARP
- 5.3 CheckForIp
- 5.4 CheckForPing
- 5.5 CheckForTCPPort
- 5.6 CheckForTCPType
- 5.7 ClientSendPacket
- 5.8 ControlLEDs
- 5.9 FillTcpArray
- 5.10 FillTcpData
- 5.11 GetDataLength
- 5.12 GetModuleRevision
- 5.13 GetSendersMAC
- 5.14 GetTcpDataPointer
- 5.15 Initialise
- 5.16 InitialiseDataLengthInfo
- 5.17 MakeArpAnswerFromRequest
- 5.18 MakeArpRequest
- 5.19 MakeEchoReplyFromRequest
- 5.20 MakeTcpAckFromAny
- 5.21 MakeTcpAckWithData
- 5.22 MakeTcpSynackFromSyn
- 5.23 PacketReceive
- 5.24 PacketSend
- 5.25 ReadArrayFromBuffer
- 5.26 ReadRegister
- 5.27 ReadStringFromBuffer
- 5.28 SetMyIPAddress
- 5.29 SetMyMACAddress
- 5.30 WriteRegister
- 6 Property reference
A set of routines used to control a ENC28J60 TCP/IP Module. Required connections VCC, Reset, GND, SCK, MISO, MOSI, CS. Leave these pins disconnected CLKOUT, ENC_WOL, ENC_INT
Please click here to download the component source project: FC_Comp_Source_TCPIP_ENC28J60.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_ENC28J60.fcfx
| CheckArpPacketIsMyreplyArp | |
CheckForARP
| CheckForARP | |
| Checks to see if the received data is an ARP request with my IP address. | |
| Length | |
CheckForIp
| CheckForIp | |
| Checks to see if the received data is an IP request with my IP address. | |
| Length | |
CheckForPing
| CheckForPing | |
| Checks to see if the received data is a Ping request | |
CheckForTCPPort
| CheckForTCPPort | |
| Checks to see if the received data is requesting the server port | |
| Port | |
CheckForTCPType
| CheckForTCPType | |
| Checks to what kind of TCP type the received data is requesting. Returns a bit field specifying the type of request. 0x01 = Ack Requires, 0x02 = Synchronise 0x10 = Ack | |
ClientSendPacket
| ClientSendPacket | |
| DestPort | |
| SourcePort | |
| Flags | |
| MaxSegmentSize | |
| ClearSeqAck | |
| NextAckNum | |
| DataLength | |
| DestMac | |
| DestIp | |
ControlLEDs
| ControlLEDs | |
| Allows both the LEDs on the Ethernet socket to be controlled. Useful for checking if the SPI communications are functioning correctly. | |
| Mode | |
| 0=Off, 1=On, 2=Auto | |
FillTcpArray
| FillTcpArray | |
| Position | |
| Count | |
| Data | |
FillTcpData
| FillTcpData | |
| Position | |
| Data | |
GetDataLength
| GetDataLength | |
| Returns the number of received data bytes after the headers | |
GetModuleRevision
| GetModuleRevision | |
| Requets the module revision number and returns the value supplied by the module's firmware. | |
GetSendersMAC
| GetSendersMAC | |
| Gets the MAC address from locations 6-11 of the IP Header | |
| MAC | |
| 6-byte Array to store the MAC address | |
GetTcpDataPointer
| GetTcpDataPointer | |
| InitialiseDataLengthInfo | |
| Initialises the data pointers to allow us to craft a response containing data | |
| MakeArpAnswerFromRequest | |
MakeArpRequest
| MakeArpRequest | |
| ServerIP | |
| MakeEchoReplyFromRequest | |
| Length | |
MakeTcpAckFromAny
| MakeTcpAckFromAny | |
| Port | |
MakeTcpAckWithData
| MakeTcpAckWithData | |
| DataLength | |
| MakeTcpSynackFromSyn | |
| Port | |
PacketReceive
| PacketReceive | |
| Attempts to receive a data packet from the ENC28J60 module. Returns the number of bytes received. | |
PacketSend
| PacketSend | |
| Attempts to transmit a data packet to the ENC28J60 module. | |
| Length | |
ReadArrayFromBuffer
ReadRegister
| ReadRegister | |
| Reads the value from a single register onboard the ENC28J60 module. | |
| Address | |
SetMyIPAddress
SetMyMACAddress
WriteRegister
| WriteRegister | |
| Writes a value to a single register onboard the ENC28J60 module. | |
| Address | |
| Data | |
