Component: Output PWM (DSP Outputs)
Author | Matrix Ltd |
Version | 1.2 |
Category | DSP Outputs |
Output PWM component
Allows the values from a buffer to be passed directly to an internal PWM output.
Please click here to download the component source project: FC_Comp_Source_DSP_PWM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_PWM.fcfx
ControlPWM
ControlPWM |
Enable or disable the PWM output, Disabled by default. | |
State |
0=Disable, 1=Enable | |
Return |
OutputPWM
OutputPWM |
Outputs a single value from the input buffer appropriatley scaled to suit the PWM. | |
Return |
OutputPWMArray
OutputPWMArray |
Outputs an array of values from the input buffer appropriatley scaled to suit the PWM. | |
Delay |
Delay in microseconds between outputting each sample. | |
Return |
