Component: Quadrature Encoder (General Input)
Revision as of 15:13, 1 August 2023 by BenR (talk | contribs)
Version 1.5
Category General Input
Quadrature Encoder component
Quadrature Encoder component implements a rotary encoder connected to two pins. Quadrature Encoders provides incremental positioning rather than absolute positioning.
Please click here to download the component source project: FC_Comp_Source_Encoder_Quadrature.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Encoder_Quadrature.fcfx
Mechanical encoders can be a bit electrically noisy when switching and so to have reliable operation it is recommended to have a simple filter as shown here.
Polling
Example program showing how to use a quadrature encoder component using a polling method. Quad_Encoder_Test
Timer Interrupt Based Polling
Example program showing how to use a quadrature encoder component using a polling method via a timer interrupt. Quad_Encoder_Timer
Interrupt On Change
Example program showing how to use a quadrature encoder component using a interrupt on pin state change interrupt (IOC). Quad_Encoder_IOC
CheckForChanges
CheckForChanges
Polling function to check changes Returns 1 for chaged, 0 for no change, 255 for error
Disable
Disable
Disables the use of the quad encoder Once this ist called, the read functions will return zeros until the next Enable() call
Enable
Enable
Enables the use of the quad encoder If this is not called, the read functions will return zeros
ReadCounter
ReadCounter
Reads the current dial counter This is a counter from -32768 to 32767
- INT Return
ReadCounter32
ReadCounter32
Reads the current dial counter as a 32-bit value This is a counter from -2147483648 to 2147483647
- LONG Return
ResetCounter
ResetCounter
Resets the current dial counter to zero
Rotate
Rotate
Simulation Rotate function to allow accurate rotation during simulation. Automatically called by any attached coupling or gearbox component.
- FLOAT Angle
Amount to rotate the shaft input in degrees
WriteCounter
WriteCounter
Sets the value of the internal count variable. Range: -32768 to 32767
- INT Value
WriteCounter32
WriteCounter32
Sets the value of the internal count variable. Range: -2147483648 to 2147483647
- LONG Value
Count Variable
Variable Type
Selects the size of the encoder count variable depending on the number of encoder counts required to be stored. The 16 bit variable counter is accessed via the ReadCounter and WriteCounter functions. The 32 bit variable counter is accessed via the ReadCounter32 and WriteCounter32 functions.
Encoder Resolution
Post Scaler
Encoders with a mechanical click will often have 4 transitions per click. 1:1 would provide the maximum output resolution. 1:4 would provide the encoder click count.
Edges Per Revolution
Number of signal transitions per revolution. E.g. for a 360 degree encoder you would likely get 360 x 4 = 1440 transitions and an accuracy of 0.25 degrees.
Resolution
The resolution of the encoder in degrees
A
Input pin A
B
Input Pin B
Repeat Rate
Simulated repeat rate when clicking and rotating the encoder
Rotation Increment
Number of degrees to rotate when performing a single quadrature pin transition.
