Component: Switch (Controls)
| Author | Steve Tandy |
| Category | Controls |
Switch component
A 2d switch component.
FREE
Switch
(5V / 11K) * 10K = 4.54545V
| GetState | |
| Reads the state of the switch (true = on, false = off) | |
| SetState | |
| Sets the switch to be on or off. | |
| bState | |
| The new state of the switch (true=on, false=off) | |
| Properties | |
| State | |
| Style | |
| Type | |
| On Label | |
| Off Label | |
| Background Colour | |
| Connections | |
| Simulations | |
