Component: Potentiometer (Analog Input)
Category Analog Input
Potentiometer component
Please click here to download the component source project: FC_Comp_Source_Potentiometer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Potentiometer.fcfx
No detailed description exists yet for this component test example file
FC6 Icon.png Potentiometer Example
Using Fixed Voltage Reference
An example of a 0 to 1023 mV meter with a resolution of 1mv.
FC6 Icon.png ADC using FVR
A PIC16F15324 is used since it has a Fixed Voltage Reference (FVR) register.
Bit0 and bit1 determine what the FVR is set at.
A line of C code is added to set the FVR to a gain of x1 = FVR of 1.024V:
FVRCON = 0b11000001;
With this setting, the Int value from ADC directly proportional voltage in mV.
E.g. a value of 732 = 732mV
Binary is used to make reading values a lot easier.
From the datasheet:
If you wanted to change the fixed voltage reference to 2.048V
Then change bit0 and bit1 of the C code to FVRCON = 0b11000010;
Filtering ADC Inputs
FC6 Icon.png LPFilter
FC6 Icon.png LPFilter2
Analogue Inputs Window
The Analogue inputs window available from the View ribbon, allows you to see the values for all of the analogue inputs which are active in your program. They can also be manually altered by dragging the mouse along one of the sliders.
Data Recorder
GetAverageByte
Fc9-comp-macro.png GetAverageByte
Read the ADC as a byte
Fc9-u8-icon.png - BYTE NumSamples
Fc9-u8-icon.png - BYTE DelayUs
GetAverageInt
Fc9-comp-macro.png GetAverageInt
Read the ADC at full bit depth
GetByte
Fc9-comp-macro.png GetByte
GetInt
Fc9-comp-macro.png GetInt
GetString
Fc9-comp-macro.png GetString
Reads the ADC as a direct voltage
GetVoltage
Fc9-comp-macro.png GetVoltage
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
Fc9-type-7-icon.png Retain Value
Fc9-conn-icon.png Appearance
Fc9-type-2-icon.png LabelColour
Fc9-type-7-icon.png Show Connection Label
Fc9-type-7-icon.png Show Pin Value
Fc9-type-16-icon.png Colour Style
Fc9-type-23-icon.png Fill
Fc9-type-2-icon.png Frame Outline
Fc9-type-23-icon.png Frame Fill
Fc9-type-2-icon.png Pointer Outline
Fc9-type-23-icon.png Pointer Fill
Fc9-type-2-icon.png Text
Fc9-type-2-icon.png Tick Mark Outline
Fc9-type-23-icon.png Tick Mark Fill
Fc9-type-2-icon.png Cap Outline
Fc9-type-23-icon.png Cap Fill
Fc9-type-13-icon.png Main Image
Fc9-type-13-icon.png Cap Image
Fc9-type-12-icon.png Style
Fc9-type-12-icon.png Type
Fc9-conn-icon.png Simulation
