Component: Temp / Humidity (SHT21) (Environmental)
Revision as of 10:26, 20 October 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Environmental
Temp / Humidity (SHT21) component
Humidity and temperature sensor using an SHT21 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Please click here to download the component source project: FC_Comp_Source_Humidity_SHT21.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_SHT21.fcfx
GetHumidityData
Fc9-comp-macro.png GetHumidityData
Returns the raw register pair value
GetHumidityInt
Fc9-comp-macro.png GetHumidityInt
returns the relative Humidity reading as an integer value
Fc9-s16-icon.png - INT Return
GetHumidityReal
Fc9-comp-macro.png GetHumidityReal
returns the Humidity reading as a float value
GetTemperatureData
Fc9-comp-macro.png GetTemperatureData
GetTemperatureInt
Fc9-comp-macro.png GetTemperatureInt
Return temperature reading as an integer value in degrees C
GetTemperatureReal
Fc9-comp-macro.png GetTemperatureReal
Return temperature reading as a float value in degrees C
Fc9-comp-macro.png Initialise
Initialises the component ready for I2C communications
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Baud rate to be used
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Simulation Comms
