Component: PWM (CAL) (Misc)
| Version | 2.2 |
| Category | Misc |
PWM component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Pulse Width Modulation peripheral.
Please click here to download the component source project: FC_Comp_Source_PWM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_PWM.fcfx
The ChangePeriod macro must be called at least once before calling the Enable macro to configure and start the PWM timer resource.
ChangeFrequency
| ChangeFrequency | |
| Advanced function for the ESP32 hardware to set the PWM output frequency. | |
| Frequency | |
| New PWM desired frequency in Hz | |
ChangePeriod
| ChangePeriod | |
| Change the Period (and prescaler) for this PWM Channel | |
| period | |
| period value PIC/AVR: 0-255 16-bit PIC: 0-65535 | |
| prescaler | |
| prescaler 1,4,16,64 | |
Disable
| Disable | |
| Disable this PWM Channel | |
Enable
| Enable | |
| Enable this PWM Channel, note the ChangePeriod macro must be called at least once before calling this function | |
GetList
| GetList | |
| Returns CHANNEL or PRESCALE list from the FCD and updates the internal property | |
| Name | |
GetValue
| GetValue | |
| Returns Named property Value | |
| Name | |
SetDuty10Bit
| SetDuty10Bit | |
| Set the Duty Cycle for this PWM Channel. PIC/AVR - Range: 0-1023 16-bit PIC - Range: 0-65535 | |
| duty | |
| Duty value 0 - 1023 | |
SetDuty8Bit
| SetDuty8Bit | |
| Set the Duty cycle (0-255) for this PWM Channel | |
| duty | |
| duty value 0 - 255 | |
SetDutyFloat
| SetDutyFloat | |
| Advanced function for the ESP32 hardware to set the PWM duty as a percentage between 0.0 and 100.0 | |
| Duty | |
SetValue
| SetValue | |
| Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD) | |
| Name | |
| Value | |
