Component: Switch Slide (Switch)
| Category | Switch |
Switch Slide component
A simple digital slide switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Please click here to download the component source project: FC_Comp_Source_Switch_Slide_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Slide_2dgi.fcfx
Switch Slide Example
(5V / 11K) * 10K = 4.54545V
ReadState
| ReadState | |
| Reads the button state as 0 for released or 1 for pressed Performs debounce if required | |
SetState
| SetState | |
| Sets the switch to be on or off. | |
| State | |
| The new state of the switch (true=on, false=off) | |
WaitUntilHigh
| WaitUntilHigh | |
| Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity | |
WaitUntilLow
| WaitUntilLow | |
| Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity | |
