Component: 7Segment (Quad TM1637) (Segment)
Revision as of 08:59, 9 June 2025 by Wiki bot (talk | contribs)
Version 4.4
Category Segment
7Segment (Quad TM1637) component
Quad seven segment display using an two pin communications bus to reduce the number of control pins. Driven using a TM1637 quad 7-segment display driver.
Version information
4, 4.0, 04-02-25, MW, Adding simulation and embedded SetBrightness function
SetBrightness
Fc9-comp-macro.png SetBrightness
Controls the brightness of the 7-seg displays
Fc9-u8-icon.png - BYTE Brightness
Range: 0-7 - 0=Darkest, 7=Brightest
Fc9-bool-icon.png - BOOL On
0 = Display Off, 1 = Display On
ShowDigit
Fc9-comp-macro.png ShowDigit
Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
Fc9-u8-icon.png - BYTE Digit
Which of the four digits to change. (0...3)
Fc9-u8-icon.png - BYTE Value
The number value to set the digit to (0...15), 16=Clear
Fc9-u8-icon.png - BYTE Colon
Whether to show the colon character. Digit 1 only.
ShowDigits
Fc9-comp-macro.png ShowDigits
Set the number and decimal point to be displayed in the given digit of the display.
Fc9-u8-icon.png - BYTE Value0
Fc9-u8-icon.png - BYTE Value1
Fc9-u8-icon.png - BYTE Value2
Fc9-u8-icon.png - BYTE Value3
ShowSegments
Fc9-comp-macro.png ShowSegments
Allows for manual control over the display segments. The colon character can also be controlled when writing to digit 1.
Fc9-u8-icon.png - BYTE Segments
The binary segment value to display
Fc9-type-16-icon.png Display Type
Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Fc9-type-7-icon.png Show Seg Labels
Show segment name labels overlayed over the component.
Fc9-type-5-icon.png DIO
Data Pin connection to TM1637 IC
Fc9-type-5-icon.png CLK
Clock Pin connection to TM1637 IC
Fc9-conn-icon.png Colours
Fc9-type-1-icon.png LED Colour
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Fc9-type-1-icon.png Body Colour
Color of the plastic casing containing the LEDs.
Fc9-type-1-icon.png Label Colour
Color for the optional LED segment labels.
Please click here to download the component source project: FC_Comp_Source_TM1637_7SEG_Quad_Driver_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TM1637_7SEG_Quad_Driver_2dgi.fcfx
