Example circuit schematic complete with component values. RREF should be a high accuracy resistor with a low PPM.
Initialize the ADS1220 ADC with default settings
- BYTE
ReadRTDResistance
ReadRTDResistance
Reads the RTD sensor and returns resistance in ohms
- FLOAT
ReadRTDTemperature
ReadRTDTemperature
Reads the RTD sensor and returns temperature in degrees Celsius using linear approximation - matches GitHub library get_temperature_from_rtd_ohms_with_linear_approx
- FLOAT
SampleDiffRAW
SampleDiffRAW
Performs a differential ADC sample between two channels and returns 24-bit raw value. Not all channel combinations are possible, see datasheet p40 section MUX. Returns 0 if the channel selection is invalid.
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Use Ready Pin
Use DRDY pin to detect when conversion is complete. If disabled, polling will be used.
DRDY Pin
Data Ready pin - goes low when conversion is complete
Configuration
Data Rate
Programmable Data Rate (SPS)
Operating Mode
Conversion Mode
PGA Gain
Programmable Gain Amplifier (PGA) gain setting
Voltage Reference
Voltage reference source
Reference Voltage
FIR Filter
IDAC Current (uA)
IDAC excitation current in microamperes. Typical values: 100, 250, 500, 750, 1000. Default: 250uA
I1MUX
I2MUX
RTD Configuration
RTD Type
RTD sensor type - determines base resistance at 0°C
RTD Configuration
Reference Resistor
High precision reference resistor value in ohms. Typically 400Ω for PT100 or 4000Ω for PT1000
Temperature Coefficient
Simulate Comms
Allows the communications to be simulated overriding the value on the panel slider controls.
