API Panel.Position.Animate
Revision as of 11:54, 16 January 2023 by Wiki bot (talk | contribs)
Animate
Blends positions from two sources to a destination over time
- HANDLE Dest
- HANDLE Start
The initial position of the animation
- HANDLE End
The final position of the animation
- UINT Millisecs
Time to take to perform the animation
- NONE Return
This call animates between two objects, storing the result in a third Dest position. It performs the operation in the background over a specified time.
Interpolation from 0 to 1
The closely related Morph call performs this operation allowing for any point on the scale to be stepped to, but it must be called manually by the user to perform an animation.
Animations can be stopped using StopAnimate
  • Add to a calculation icon:
    ::Panel.Position.Animate(dest, start, end, millisecs)
