API Panel.PCloud.SetPos
Revision as of 11:54, 16 January 2023 by Wiki bot (talk | contribs)
SetPos
Sets the position for the point cloud to be located at
- HANDLE PCloud
The handle to the cloud to adjust the position of
- HANDLE Pos
The position to display the cloud at
- BOOL Track
Automatically update the cloud to match changes in the position
- NONE Return
This sets the position the point cloud will fill in. That is for any axis the range -1 to 1 in the point cloud will be mapped to the opposite walls of the positions bounding box.
If Track is true, the point clouds position will automatically be updated when the position changes, otherwise the point cloud remains at the specified position even if the owning object moves.
Note that for component positions the point cloud will redraw when the components position is altered, as moving a component invokes a redraw of the screen. However, adjusting dynamic position objects does not redraw the screen, and Update must be called to force a redraw of the point cloud.
  • Add to a calculation icon:
    ::Panel.PCloud.SetPos(pcloud, pos, false)
