API Component.Property.GetListIndex
Revision as of 11:54, 16 January 2023 by Wiki bot (talk | contribs)
GetListIndex
Gets a single lists index value from a property by line number
- HANDLE Handle
The component handle to get the property of
- STRING Property
The textual name of the property
- ULONG LineIx
The lists line (first is zero) to read the index of
- STRING Return
Given a Property which is a list type, this gets the index (3-character) part of the line corresponding to LineIx, with zero being the first line. This index can then be used in GetListItem and related calls.
The lines of the property are stored in its filter - see GetFilter.
No checks are performed to establish the property is of the correct type.
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Component.Property.GetListIndex(handle, "property", lineix)
