API FCD.GetItemHandle
Revision as of 11:55, 16 January 2023 by Wiki bot (talk | contribs)
GetItemHandle
Gets a FCD items handle, suitable for traversal with the Tree API
- HANDLE PathName
An existing handle or the '.' separated path through the FCD to look in
- STRING ItemName
The name of an item in the path to find
- HANDLE Return
This will get a handle suitable for traversal by the Tree API which is a collection of functions suitable for traversing the FCD files.
FCD files are XML files. The PathName must be a list of items, not including the XML root tag of the tags where the XML attribute ItemName is to be located. So to extract a handle to the FLASH memory size Pathname="device.memory" and ItemName="bytes".
If the ItemName is not found in the specified location then a 0 handle is returned.
  • Add to a calculation icon:
    result = ::FCD.GetItemHandle(pathname, "itemname")
