API File.Open
Revision as of 11:55, 16 January 2023 by Wiki bot (talk | contribs)
Open
Opens the existing file as a standard stream
- STRING Filename
A textual filename to open
- BOOL Read
Set to enable read access
- BOOL Write
Set to enable write access
- BOOL Monitor
Set to enable monitoring of the file
- HANDLE Return
  • Add to a calculation icon:
    result = ::File.Open("filename", true, false, true)
