Component: Dashboard Knob ()
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.3
Category
Dashboard Knob component
Rotary control designed for the dashboard panel. Has customisable value markings around the control. Simulation only - the control value can be read using simulation macros but is not connected to a chip pin.
Please click here to download the component source project: FC_Comp_Source_Dashboard_Knob.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Dashboard_Knob.fcfx
Simple example showing how to use the simulation dial components as a meter display for use in monitoring type applications. Meters
Range
Minimum
The minimum value that the knob will output (fully counter_clockwise)
Maximum
The maximum value that the knob will output (fully clockwise)
Style
BG Color
Background colour behind the knob labelling - may be transparent.
Positive Color
Colour for number labels which are less than zero.
Negative Color
Colour for number labels which are greater than zero.
Label Color
Colour for the name label text.
Resolution
How much detail to draw for the labels.
Marks
Divisions
Number of labelled positions around the knob.
Subdivisions
Number of divisions between the numbered ones.
Numbers
Decimals
How many decimal places to show on the number labels.
Text Size %
Height of the number label text.
Font
Font for the number labels.
Text
Text for the name label.
Text Size %
Text height for the name label.
Font
Font for the name label.
