Component: Keypad (Cursor 3x3) (Keypad)
Revision as of 13:11, 7 February 2023 by Wiki bot (talk | contribs)
Category Keypad
Keypad (Cursor 3x3) component
A preset keypad component with up, down, left and right cursors, and a selection of function keys, in a 3 by 3 matrix. Return values (Index or Number) are... 0 = F1, 1 = Up, 2 = F3 3 = left, 4 = OK, 5 = right 6 = F2, 7 = down, 8 = F4. 255 = No key pressed.
Please click here to download the component source project: FC_Comp_Source_Keypad_Cursor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Keypad_Cursor.fcfx
GetAscii
GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
GetIndex
GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
GetNumber
GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
GetString
GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string.
- STRING Return
WaitPressed
WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
WaitReleased
WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Dimensions
Keys
Number of columns (left to right) in the array of keys. Must be a value from one to four.
Return Values
ASCII
A list of return values for the 'GetString' and 'GetASCII' macros. Enter a string with one character per key, in order of key scanning. Columns are counted first (left-to-right), then rows (direction set by the 'First Row' property) e.g. for a 2*2 grid, the order would be... [Row0, Column0], [Row0,Column1], ][Row1, Column0], [Row1, Column1]
Numbers
A list of return values for the 'GetNumber' macro. Enter a comma separated list with one integer value per key, in order of key scanning. Columns are counted first (left-to-right), then rows (direction set by the 'First Row' property) e.g. for a 2*2 grid, the order would be... [Row0, Column0], [Row0,Column1], ][Row1, Column0], [Row1, Column1]
Output Mode
Port
Backplate Colour
Button 1
Key colour
Set the colour of the key body here. This is applied to all objects making up a key, including the background colour of any text labels.
Label colour
Set the colour for the default 'ASCII' text label on the key-cap. This setting will be ignored if a bitmap is set for the key label.
Button 2
Key colour
Up arrow colour
Button 3
Key colour
Label colour
Button 4
Key colour
Left arrow colour
Button 5
Key colour
Label colour
Button 6
Key colour
Right arrow colour
Button 7
Key colour
Label colour
Button 8
Key colour
Down arrow colour
Button 9
Key colour
Label colour
