Component: FAT Dummy (File)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.7
Category File
FAT Dummy component
FAT component allowing access to read and write files on a SD, SDHC or MMC card. The component automatically detects the filesystem on the card on initialise so FAT16 and FAT32 are fully supported.
Please click here to download the component source project: FC_Comp_Source_File_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_File_Dummy.fcfx
Reading data from a text file
Example to read a text file from a SD card or from a text file in simulation and display on a 16 x 2 character LCD. The text file needs to be in the same directory as the Flowcode .fcfx project file for the simulation to run correctly. FAT Read File File:Test.txt
Console showing current 512 byte sector data
Console showing high level FAT status
Parsing a standard .BMP image file
Example to read a bitmap image file from a SD card or from a bitmap file in simulation and display on a graphical LCD. The bitmapfile needs to be in the same directory as the Flowcode .fcfx project file for the simulation to run correctly. FAT display Bitmap Demo bitmap files referenced in the example.
File:FATDemoBitmaps.zip
Picture showing a bitmap being displayed on a GLCD component.
Data logger Simple
Example showing how to take a collection of analogue readings and save them into a text based file, the simple way. FAT data logger simple but slow
Data logger Advanced
Example showing how to take a collection of analogue readings and save them into a text based file, the fast way. FAT data logger fast
Log Keypad Presses
Example showing how to poll a keypad for key presses. Each key press is shown on an LCD and appended to a log file as an ASCII character using the FAT component. Keypad Press Log
Streaming Audio Files
Example showing how to steam out .wav audio files from an SD card using a 16-bit @ 16KHz file format. A free program such as Audacity can be used to create or edit the .wav files. WAV Streaming
AppendByteToFile
AppendByteToFile
- BYTE Data
AppendStringToFile
AppendStringToFile
- STRING Data_String
CloseFile
CloseFile
CreateFile
CreateFile
- STRING Filename
DeleteFile
DeleteFile
- STRING Filename
MoveToNextFileSector
Attempts to move to the next sector in the file. When reading a file you would leave force next sector set to 0. When writing a file you would leave force next sector set to 1 to allow new sectors to be created as the file grows. Returns 0 for success
- BYTE Force_Next_Sector
OpenFile
OpenFile
Searches for and opens a file for reading or writing from within the current directory on the disk. Returns 0 for success.
- STRING Filename
8.3 filename of the file we are trying to open e.g. "file.txt"
OpenFolder
OpenFolder
- STRING Folder_Name
ReadByteFromFile
ReadByteFromFile
Reads a byte from the currently open file. Auto increments the position in the file. A return value of 0 may signify the end of the file has been reached (depending on the contents of the file).
ReadByteFromIndex
ReadByteFromIndex
Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer.
- ULONG Address
ReadFileLength
ReadFileLength
Returns the number of bytes in the current sector that are used by the current open file. Return = 512 - Sector is filled with file data Return < 512 - Last sector of the file, Retval specifies how many bytes of data are remaining in the sector
- INT Return
ReadFileSize
ReadFileSize
Reads the entire size of the current file in bytes.
- ULONG Return
WriteByteToBuffer
WriteByteToBuffer
- UINT Address
- BYTE Data
WriteFileSector
WriteFileSector
