Component: LED Cube (Misc Circuit)
Revision as of 13:11, 7 February 2023 by Wiki bot (talk | contribs)
Author Ben Rowland 2014
Category Misc Circuit
LED Cube component
LED Cube component for driving 3D arrays of LEDs. A typical cube could consist of 4x4x4 or 8x8x8 but does not necessarily need to be a cuboid.
Please click here to download the component source project: FC_Comp_Source_LEDCUBE.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LEDCUBE.fcfx
Clear
Clear
Clears the contents of the display to 0x0000
- BYTE SwitchBuffers
0=DoNotSwitch 1=SwitchAutomaticallyWhenDone
ConvColourToRGB
ConvColourToRGB
Reads the individual RGB colour values from a single UINT colour value. Return Index: 0=Red, 1=Green, 2=Blue
- UINT Colour
- STRING Return
ConvRGBToColour
ConvRGBToColour
Converts RGB values into a single UINT colour parameter to use with other functions.
- BYTE Red
- BYTE Green
- BYTE Blue
DisplayCharacter
DisplayCharacter
This macro allows a character to be displayed on the screen
- BYTE Character
- BYTE X1
- BYTE Y1
- BYTE Z1
- BYTE Font
Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
- BYTE Axis
0=XY, 1=XZ, 2=YZ
- BYTE Orientation
0=Normal, 1=HFlip. 2=VFlip, 3=HFlip & VFlip
- UINT Colour
Specifies the foreground colour
DrawCuboid
DrawCuboid
Draws a basic 3D cuboid onto the LEDs
- BYTE X1
- BYTE Y1
- BYTE Z1
- BYTE X2
- BYTE Y2
- BYTE Z2
- BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- UINT Colour
DrawLine
DrawLine
Draws a basic 3D line onto the LEDs
- BYTE X1
- BYTE Y1
- BYTE Z1
- BYTE X2
- BYTE Y2
- BYTE Z2
- UINT Colour
GetColour
GetColour
Reads the colour value from a single pixel in the active buffer as a 16-bit value. Bits 0-4 = Red Bits 5-10 = Green Bits 11-15 = Blue
- BYTE X
- BYTE Y
- BYTE Z
Sets up the data memory and draws the simulated LED cube on the panel.
PWMTimer
PWMTimer
Interrupt driven macro to clock out the signals to the LEDs in the cube. To be called as part of a high frequency hardware timer interrupt or software loop to drive the cube hardware, Min Frequency = 60(Hz) * 8(Height) * 32(5-bitColourChannelValue)
ResetRotations
ResetRotations
Resets the rotation count variables allowing for a new rotation to be started
RotateDisplay
RotateDisplay
Shifts the contents of the display by the number of vertices specified
- INT X
Number of pixels to shift the display -7 to 7
- INT Y
- INT Z
RotateShellXY
RotateShellXY
- BYTE Direction
- BYTE Shell
RotateShellXZ
RotateShellXZ
- BYTE Direction
- BYTE Shell
RotateShellYZ
RotateShellYZ
- BYTE Direction
- BYTE Shell
SetColour
SetColour
Sets a pixel colour in the none active buffer using a 16-bit colour value Bits 0-4 = Red Bits 5-10 = Green Bits 11-15 = Blue
- BYTE X
- BYTE Y
- BYTE Z
- UINT Colour
16-bit Colour Value (MSB B5, G6, R5 LSB)
ShiftDisplay
ShiftDisplay
- INT X
- INT Y
- INT Z
- BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
SwitchBuffers
SwitchBuffers
Switches the current display buffer to the updated buffer to allow for seamless updates when undergoing heavy calcaulations.
- BYTE WaitForSwitch
0=DoNotWait, 1=Waits for switch to occur
LEDs
Width (X)
The number of LEDs wide
Depth (Y)
The number of LEDs deep
Height (Z)
The number of LEDs tall
LED Count
Number of LEDs required by the component
LED Type
Common Type
Wiring Order
Specifies the order of the wiring of the LEDs from lowest bit to highest
Driver Pre Delay
Number of micro seconds to wait between switching off the driver and clocking out the new signals. Used to remove any ghosting effects visible on the display due to slow driver switch off times.
Driver Post Delay
Clock Pin
Data Port
Enable Port
LED Size
Size of each LED on the panel
Spacing
Number of units of spacing between each LED
Transparent
If set to yes then a LED which is completely switched off will be set to transparent, If set to no then the LED will be shown as black.
Toggle Pins
Determines if the pins are toggled as part of the PWMTimer macro during simulation. During simulation you probably don't want the pins toggling as it will slow down simulation. The only exception may be if you want to see the signals in the scope window. Does not effect the compiled embedded code.
