Component: Digital Potentiometer (AD528X) (Analog Output)
Revision as of 09:31, 19 July 2024 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Analog Output
Digital Potentiometer (AD528X) component
The AD528X device range supports up to 2 digital potentiometers or rheostat outputs. 256 possible output resistance values for each channel. Note: The initial value of both channels will start at 0.
DecrementWiper
DecrementWiper
Decrements a single volatile wiper value
- BOOL Index
0=Channel1 /1=Channel2
IncrementWiper
IncrementWiper
Increments a single volatile wiper value
- BYTE Index
Range: 0-1
Startup the I2C peripheral ready for communications.
ReadTapValue
ReadTapValue
Reads the tap value of the seelcted channel
- BOOL Index
0=Channel 1 / 1=Channel 2
SetWiper
SetWiper
Sets the value of a single wiper
- BOOL Index
- BYTE Value
256 Taps Range: 0-255
I2C Properties
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Device Properties
Number of Outputs
Address
Address Bits
Simulate Comms
I2C Simulation
API
Please click here to download the component source project: FC_Comp_Source_AD528x_Digital_Pot.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AD528x_Digital_Pot.fcfx
