API Console.GetLineBytes
Revision as of 15:34, 10 May 2013 by Admin (talk | contribs) (XML import of API auto-gen)
wiki page name
ConsoleGetLineBytes
Reads a line of bytes from the given console extending the array if needed
HANDLE ConsoleHandle
A valid console windows handle
ULONG Line
The zero-based index of the line to read the data from, pass -1 for final line
BYTE[] Buffer
A buffer to read the data into
ULONG Offset
An offset into Data of the first byte to write to
ULONG MaxBytes
The number of bytes to read, -1 for full line
The default value for this parameter is: -1
ULONG
Calling in a calculation:
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon: result = ::Console.GetLineBytes(consolehandle, line, _arraybuffer, offset, maxbytes)
