Component: Digital Potentiometer (MCP44XX) (Analog Output)
Revision as of 13:11, 7 February 2023 by Wiki bot (talk | contribs)
Category Analog Output
Digital Potentiometer (MCP44XX) component
The MCP44XX device range supports 4 digital potentiometers or rheostat outputs. 129 or 257 possible output resistance values for each channel.
Please click here to download the component source project: FC_Comp_Source_MCP44xx_Digital_Pot.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP44xx_Digital_Pot.fcfx
DecrementWiper
DecrementWiper
Decrements a single volatile wiper value
- BYTE Index
Range: 0-3
IncrementWiper
IncrementWiper
Increments a single volatile wiper value
- BYTE Index
Range: 0-3
Startup the I2C peripheral ready for communications.
ReadAddress
ReadAddress
Reads a value from one of the registers on the device
- BYTE Address
Range: 0-15
SetWiper
SetWiper
Sets the value of a single wiper
- BYTE Index
Range: 0-3
- UINT Value
129 Taps Range: 0-128 / 257 Taps Range: 0-256
- BOOL MemoryType
0=Volatile, 1=Nonvolatile
WriteAddress
WriteAddress
Writes a value to one of the registers on the device
- BYTE Address
Range: 0-15
- UINT Value
Range: 0-256
I2C Properties
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Device Properties
Number of Taps
Address Bits
Simulate Comms
