Component: Map Function (Calculation)
Revision as of 08:59, 9 June 2025 by Wiki bot (talk | contribs)
Author medelec35
Version 2.0
Category Calculation
Map Function component
The map function is intended to change one range of values into another range of values. For example. Output from a temperature sensor is in centigrade. you can map it to give the result in Fahrenheit. To do that set: InMin to 0, InMax 100, OutMin to 32 & OutMax to 212
A simple example showing how to take a value from an adc input with the range 0-255 and mapping this to a predetermined range of 50-150 to drive a PWM output.
Mapping ADC to PWM
MapByte
MapByte
Map function for byte type variables
- BYTE Value
Main variable used for map function
- BYTE InMin
Lowest input value
- BYTE InMax
Highest value input
- BYTE OutMin
Lowest value after conversion
- BYTE OutMax
highest value after conversion
- BOOL ClampMinMax
Clamp min & max so result does not go above or below set values. 0=No, 1=Yes
MapFloat
MapFloat
Map function for floating point type variables
- FLOAT Value
- FLOAT InMin
Lowest input value
- FLOAT InMax
Highest value input
- FLOAT OutMin
- FLOAT OutMax
- BOOL ClampMinMax
- FLOAT Return
MapInt
MapInt
Map function for signed int type variables
- INT Value
- INT InMin
Lowest input value
- INT InMax
Highest value input
- INT OutMin
- INT OutMax
- BOOL ClampMinMax
- INT Return
MapLong
MapLong
Map function for signed long type variables
- LONG Value
- LONG InMin
Lowest input value
- LONG InMax
Highest value input
- LONG OutMin
- LONG OutMax
- BOOL ClampMinMax
- LONG Return
MapUInt
MapUInt
Map function for unsigned int type variables
- UINT Value
- UINT InMin
Lowest input value
- UINT InMax
Highest value input
- UINT OutMin
- UINT OutMax
- BOOL ClampMinMax
MapUlong
MapUlong
Map function for unsigned long type variables
- ULONG Value
- ULONG InMin
Lowest input value
- ULONG InMax
Highest value input
- ULONG OutMin
- ULONG OutMax
- BOOL ClampMinMax
- ULONG Return
Please click here to download the component source project: FC_Comp_Source_Map-Function.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Map-Function.fcfx
