Component: Temp / Humidity (SHT31) (Environmental)
Revision as of 08:59, 9 June 2025 by Wiki bot (talk | contribs)
Version 2.0
Category Environmental
Temp / Humidity (SHT31) component
Humidity and temperature sensor using an SHT31 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
An example displaying real temperatures and humidity using floats,
SHT31 Example
GetHumidityInt
GetHumidityInt
returns the relative Humidity reading as an integer value
- INT Return
GetHumidityReal
GetHumidityReal
returns the Humidity reading as a float value
- FLOAT Return
GetTemperatureInt
GetTemperatureInt
Return temperature reading as an integer value in degrees C
- INT Return
GetTemperatureReal
GetTemperatureReal
Return temperature reading as a float value in degrees C
- FLOAT Return
Configures the I2C peripheral and puts the sensor into one shot mode ready to be sampled. Must be called before calling any of the other component macros. Returns 1 if the sensor has been intialised correctly, else returns 0.
Address
Selects the correct device address based on the ADDR pin connection to VDD or VSS.
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Simulation Comms
Please click here to download the component source project: FC_Comp_Source_Humidity_SHT31.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_SHT31.fcfx
