Component: Output Digital (DSP Outputs)
Revision as of 10:26, 20 October 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Outputs
Output Digital component
Allows the values from a buffer to be read. Either a value at a time or as an array.
Please click here to download the component source project: FC_Comp_Source_DSP_Output.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Output.fcfx
GetByte
GetByte
Returns a byte value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
GetByteArray
GetByteArray
Returns an array of byte values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- BYTE Data
- UINT Count
GetFloat
GetFloat
Returns a float value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- FLOAT Return
GetFloatArray
GetFloatArray
Returns an array of float values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- FLOAT Data
- UINT Count
GetInt
GetInt
Returns an integer value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
GetIntArray
GetIntArray
Returns an array of integer values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- UINT Data
- UINT Count
GetLong
GetLong
Returns a long value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- ULONG Return
GetLongArray
GetLongArray
Returns an array of long values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- ULONG Data
- UINT Count
Connect To
Auto Scale
Automatically scale the buffer type to the output type Yes: Provide automatic scaling No: Transfer data as is, maybe truncated
