Component: RGB LED WS2801 (LEDs)
Revision as of 21:01, 23 December 2025 by Wiki bot (talk | contribs)
Version 2.0
Category LEDs
RGB LED WS2801 component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Supports Bit Banged or SPI peripheral based data modes.
1D Configuration
In the 1D configuration each LED simply follows on from the last in a chain.
2D Configuration
In the 2D configuration each LED follows on from the last in a chain which travels back and forth through the columns a row at a time.
3D Configuration
In the 3D configuration each layer follows the 2D configuration with each layer then following on by mirroring the layer below. First layer connections are shown in Red and second layer connections are shown in Blue.
3V3 Microcontrollers
Note you may have to voltage shift the micro controller control pins to meet the 0.8 * VDD minimum requirement. E.g. if VDD is 5V then the input voltage needs to be at least 4V.
A simple buffer IC could be used to do the voltage shifting.
RGB Mood Light
A simple example using three potentiometers to set the individual Red, Green and Blue channels of the LED colour. MoodLight
Animated Light
A simple example which picks a random colour assigns it to the first LED, then shifts and repeats. AnimatedLightStrip
Animated Light Cascade
A simple example which picks a random colour assigns it to the first LED, then shifts and repeats. AnimatedLightCascade
DrawCuboid3D
DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
- BYTE X1
- BYTE Y1
- BYTE Z1
- BYTE X2
- BYTE Y2
- BYTE Z2
- BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE R
- BYTE G
- BYTE B
DrawLine2D
DrawLine2D
Draws a line on a 2D array of LEDs
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE R
- BYTE G
- BYTE B
DrawLine3D
DrawLine3D
Draws a line on a 3D array of LEDs
- UINT X1
- UINT Y1
- UINT Z1
- UINT X2
- UINT Y2
- UINT Z2
- BYTE R
- BYTE G
- BYTE B
DrawRectangle2D
DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
- BYTE DrawStyle
- BYTE R
- BYTE G
- BYTE B
GetLEDColour
GetLEDColour
Sets the colour of a single LED in RAM as a 1D array.
- UINT LED
LED to change the colour / Range: 0 to (LED Count - 1)
- BYTE ColIdx
0 = R, 1 = G, 2 = B
GetLEDIndex2D
GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
- UINT X
LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT Y
LED Row to change the colour / Range: 0 to (LED Row - 1)
GetLEDIndex3D
GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
- UINT X
- UINT Y
- UINT Z
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the WS2801 ICs in the chain.
Refresh
Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
SetAllLEDColour
SetAllLEDColour
Sets the colour of all the LEDs in RAM
- BYTE R
- BYTE G
- BYTE B
SetBrightness
SetBrightness
Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
- FLOAT Scaler
Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
SetBrightnessByte
SetBrightnessByte
- BYTE Scaler
Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
SetLEDColour
SetLEDColour
- UINT LED
- BYTE R
- BYTE G
- BYTE B
ShiftLEDs1D
ShiftLEDs1D
Shifts the LED colours in 1D and wraps
- BYTE Direction
0 = Forwards, 1 = Backwards
- BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
ShiftLEDs2D
ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
- INT X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
- INT Y
- BYTE DataMode
ShiftLEDs3D
ShiftLEDs3D
- INT X
- INT Y
- INT Z
- BYTE DataMode
LED Properties
LED Arrangement
Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
LED Count
Total number of LEDs in the design
Column Spacing
X Spacing Between LEDs on the Panel
Output Mode
Sets the output mode used to drive the data to the LEDs Bit Banged Mode = Allows Any I/O Pin but may be slower SPI Mode = Fixed SPI Peripheral Pins but may be faster - Note that the SPI MISO pin will not be available for general I/O
Connection Properties
Data Pin
LED Data Pin - Connected to the Data In pin of the first WS8201 IC.
Clock Pin
LED Clock Pin - Connected to the Clock In pin of the first WS8201 IC.
API
Please click here to download the component source project: FC_Comp_Source_LED_WS2801.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_WS2801.fcfx
