Component: SCADA (Dummy) (SCADA Slaves)
Revision as of 13:12, 7 February 2023 by Wiki bot (talk | contribs)
Category SCADA Slaves
SCADA (Dummy) component
Dummy SCADA Slave component to enable injector referencing. Supports: Digital IO / ADC / I2C / SPI / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_OLD_API_Slave_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_OLD_API_Slave_Dummy.fcfx
I2CInitialise
I2CInitialise
I2CReceive
I2CReceive
- BOOL Last
I2CRestart
I2CRestart
I2CSend
I2CSend
- BYTE DataOut
- BOOL Return
I2CStart
I2CStart
I2CStop
I2CStop
IOGetInputPin
IOGetInputPin
- BYTE Pin
Range: 0-13
- BOOL Return
IOSetOutputPin
IOSetOutputPin
- BYTE Pin
Range: 0-13
- BOOL State
Range: 0-1
SPIInitialise
SPIInitialise
SPIPrescaler
SPIPrescaler
- BYTE Prescaler
Range: 0-2
SPITransfer
SPITransfer
- BYTE DataOut
