Component: SPI Master (EB013) (E-blocks 1)
Revision as of 13:12, 7 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category E-blocks 1
SPI Master component
Low level routines for controlling or interacting with an SPI interface. SPI or Serial Peripheral Interface is a bus used for board level communications between devices. A target microcontroller will usually have at least one hardware SPI peripheral built in. If the hardware SPI pins are in use or more SPI channels are required then there is also a software mode available. Has additional functions to work with the E-blocks EB013 SPI hardware.
Please click here to download the component source project: FC_Comp_Source_SPI_Legacy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SPI_Legacy.fcfx
DACSendChar
DACSendChar
Send a byte to the digital to analogue converter (DAC) on the EB013 SPI E-block.
- BYTE Data
Data byte to output using the DAC
DisableFram
DisableFram
Disable the SPI RAM chip on the EB013 SPI E-block.
EnableFram
EnableFram
Enable the SPI RAM chip on the EB013 SPI E-block.
FramOutput
FramOutput
Send a value to the RAM on the EB013 SPI E-block.
- BYTE Char
GetChar
GetChar
General purpose SPI get byte macro
GetString
GetString
Attempts to read a string of bytes from the SPI bus.
- BYTE NumBytes
- BYTE Ch
- STRING Return
Activates the SPI peripheral and claims control over the I/O pins.
NVMGetChar
NVMGetChar
Reads a byte from the non-volatile memory device on the EB013 SPI E-block.
- ULONG Address
NVM Address to read data from
NVMSendChar
NVMSendChar
Send a byte to the non-volatile memory device on the EB013 SPI E-block.
- ULONG Address
NVM Address to write data to
- BYTE Data
Data Byte to write to the sepected memory location
SendChar
SendChar
General purpose SPI send byte macro
- BYTE Char
SendString
SendString
Sends a string of bytes to the SPI bus
- STRING Str
UnInitialise
UnInitialise
Deactivates the SPI peripheral leaving the I/O pins in a state where they can be used for general purpose I/O.
SPI Channel selector
MOSI
MISO
CLK
DAC En
DAC enable pin - only used with the EB013 SPI E-block
NVM En
NVM enable pin - only used with the EB013 SPI E-block
Bus Settings
Board Version
The Latest version of the E-block have a newer NVM IC which requires 3 address bytes instead of 2 address bytes. If you find that the NVM is not responding to commands then try changing the version property to match the version of the E-block. The version is written on the board as EB013-00-X where X is the version number.
Prescale
Prescale option selector
Clock Phase
Clock Polarity
Sample Point
Data bit read sample point
Label used to identify the component on the panel.
API
