Component: Output Digital Pin (DSP Outputs)
Revision as of 10:26, 20 October 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Outputs
Output Digital Pin component
Allows the values from a buffer to be passed directly to a digital output pin based on a defined threshold.
Please click here to download the component source project: FC_Comp_Source_DSP_OutputPin.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_OutputPin.fcfx
SetPin
SetPin
Takes the value from the connected DSP buffer and outputs to the selected pin based on the selected threshold values.
Connect To
Output Pin
Threshold Value
Sets the level at which the pin goes into the active state. >= the threshold the pin will be in the active state. < the threshold the pin will be in the none active state.
Pin State
Selects the output level to use when the pin is in the active state. Active High - Pin will pull to VCC (high) when active and pull to VSS (low) when none active. Active Low - Pin will pull to VSS (low) when active and pull to VCC (high) when none active.
