Component: Potentiometer (Trimmer) Free ()
Revision as of 13:13, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.4
Category
Potentiometer (Trimmer) Free component
Trim Pot for 0.1mm pitch PCB. With finger dial knob. Pointer colour can be changed from component properties.
Please click here to download the component source project: FC_Comp_Source_knob_trim_finger_free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_knob_trim_finger_free.fcfx
Start Angle
Sweep Angle
Color
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
