Component: Modified Moving Average Float (Calculation)
Revision as of 11:01, 25 February 2026 by Wiki bot (talk | contribs)
Category Calculation
Modified Moving Average Float component
Allows a value from a sensor to be averaged out filtering out high frequencies and removing noise. Modified moving average means we maintain a sum of the last n number of samples. On each new sample we subtract the previous result and then add in the latest raw sample.
Filter
Filter
Performs the filtering function, passing in the latest sampled value and outputting the latest filtered value.
- FLOAT Value
Latest sample to add to the filter
- FLOAT Return
InitialiseFilter
InitialiseFilter
Preload the filter with the specified value and sets the number of samples to average over. Must be called before calling the filter macro.
- FLOAT FilterValue
Initial value to load into the filter, e.g. 0
- UINT NumSamples
Specifies the number of samples to average over.
Please click here to download the component source project: FC_Comp_Source_ModifiedMovingAverageFloat.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ModifiedMovingAverageFloat.fcfx
